kigglys flexplate adapter kit help
dsmallday609
Aug 5, 2011
brownsmills, New Jersey
need the order of installation for 6 bolt to a 2g auto trans.. got the kit n now im feeling stupid trying to put it together... order of steps to installation anyone?
well,. hmmk. bolt the kiggly flex plate to the crank with the 6 bolt adaptor plate (big washer with 6 holes for the plate bolts to go through). Torque the bolts to spec. Begin installing the auto trans with torque converter installed in the trans FULLY. it should be around a 1/2" into the trans when fully installed. Then litft the trans up by the designated eyelet on top,... into place against the block. the center stub of the torque conv. will be inserted into the pilot bearing huhuhuh. install the trans bolts, and make sure your dowels are there. then rotate the engine to line up the flex/drive plate holes to the torque converter holes. snug them till all 4 are installed, then torque them to spec in a cris cross pattern. install axles, suspension, cooler lines, elec. connectors, and line up the gear selector with the hole in the housing aroung it, make sure the selector knob is in neutral, then tighten the under hood selector cable to the selector bracket. fill the trans with 6 qrts ofyour prefered atf. start the engine and runs for ONLY 5 sec whilst going through the gears on the selector knob. the fill with another 3 qrts of atf. then try it out on the road, making a few stops periodically to check the fluid level ( while in neutral ). I guess thats it. I try hard to forget all the HELL i went through with my auto trans.
thanx bro.... i been getting all sorts of frustrated with this damn car... just trying to have the motor in before it gets too cold....
