Keyless install
wilfredorivera1
Apr 15, 2005
cleveland, Ohio
Ok my wife got me this keyless entry from some auto parts and I am trying to install it my self but I have no idea where all this locations are under the dash. Please help!!!
I found these!!!!!!!!!
Battery WHITE (+) IGNITION SWITCH HARNESS
Ignition BLACK/WHITE (+) IGNITION SWITCH HARNESS
Starter BLACK/RED (+) IGNITION SWITCH HARNESS
WIRE COLOR POLARITY LOCATION
Where????
Parking Lights GREEN/WHITE (+) DR.KICK OR FUSE BOX
Horn GREEN/RED (-) STEERING COLUMN
I looked for these but no luck
Power Unlock BROWN/RED (-) NEGATIVE TRIGGER ( where is this at?)
PowerLock RED/BLUE (-) BEHIND FUSEBOX OR 20 PIN CONN HIGH DR KIck
What are these? and do i need to worry about them?
Driver Mtr Unlock BLUE/RED (-) DRIVERS KICK PANEL
Driver Mtr Lock BLUE/BLACK (-) DRIVERS KICK PANEL
Pas Mtr Unlock BLUE/RED (-) PASS KICK PANEL
Thank you
Will Rivera
Defiant said:
Do not bump your threads. Ever.
ROFL ROFL ROFL your tone kills me everytime defiant LOL.
Anyways have you tried looking for a similar install procedure for a different keyless entry? Also if you don't have one go buy ATLEAST a Chilton's manual it has all of the wiring diagrams in it and you can easily figure the wire colors out. Did the keyless entry not come with any kind of instructions if not was it stolen :confused: LOL. Do some searches on Google for the kind of system you have I'm sure you will find some kinda help out there somewhere.
:sosad: Sorry about the bump! But I was not aware of that specific rule. I did get the instructions with system and I did search every where but I am really confused when I get under the dash. All the cables look the same and sometimes there are cables colored the same way. Any way I just need the two from the locks.
Thanks will!!!!!!!
