Just order my headlights!!!
tazraz01
72
Jan 8, 2005
Rowlett, Texas
Check out the new headlights i just ordered :D should look awesome since my eclipse is black :thumb:
I have those headlights i like the look, mine have a blue projector glass. Did you know that you have to use your wiring from you rheadlights you have now, or make your own harness. Also on a side note they don't have a warrenty and my halo light burnt out 2 weeks after i installed them. It may not happen to yours but i just wanted to give you fair warning.
I have some just like that and my halo LED's went out after two weeks also. I then took the headlights apart so I could paint match the black to match my white and I bought some nice deep blue LED's from Radio Shack and had a Audio shop put them in. They look so badass now and when the headligts are on it is hard to see the blue so the cops don't mess with me. I would also suggest that you get some LED turn signals to go with those. I just ordered some from a company on Ebay called Velocity LED's. I ordered the amber ones that light up in a halo but instead of the LED's pointing straight forward they are poined sideways so they reflect off of the chrome piece and give off more light.
http://stores.ebay.com/Velocity-leds_W0QQsspagenameZl2QQtZkm This is were I got them I believe they have good prices becuase for just one straight firing at Autozone they are 9.99.
LEDs burning out after 1-2 wks...... that sounds like a classic case of a lack of proper resistor in-line with the LED(s), doesn't it?
:confused:
-A
two weeks and the Halos burn out??? Ouch, i dont really think i wanna go spend close to 200 bucks for my lights to burn out that fast...Not really sure what to do here :cry:
Doesnt the halo just light up with a normal bulb like an H4 or something? Can't you replace it even if it does burn out after 2-3 weeks without taking the thing apart? :confused:
If I was you, I would just wait for the LEDs to die. Then take the headlights apart and replace the LEDs with super bright blue or white ones. The ones you get from radio shack are probably of better quality and emmit more light anyways.
i had a set like that on my old talon, i liked them just make sure you have them properly aligned otherwise its hard to see but i would buy another set :thumb:
