JDM swap, to do's:
I-luv-em-all
602
5
May 25, 2004
Regina,
Im getting a jdm motor right away here, and im wondering what are some addition type things are i should do while the motor is out of the car? I was thinking of maybe a new clutch, axle boots, swap the cyclone manifold for the stock one, maybe remove the A/C. Also how are the JDM throttle bodys are they better or worse, all my vac lines are eliminated anyway, what else do u think i should do? or any suggestions on anything in general? thanks for the help.
You need to use your old water neck, as the galants have the radiator cap on the radiator... of all places.
I am in the middle of this swap, so if you have any questions, feel free to ask. The only diff is I never had a USDM engine to swap out.. I am starting from pretty much scratch.
The front mount I got on my JDM engine is NOT the right front mount. But again, if you are swapping out your old one, use those mounts.
  • Wanted 6 bolt NT water pipe
    • chrisman287
