JDM Motor Question
EclipseOwner95
704
11
Oct 16, 2002
Jacksonville, Florida
ok i got a " jdm " motor for my 1g, and i have a few questions, i have a full usdm motor to use parts off if i need, first question
1. the intake manifold dosnt say cyclone on it, there fore it does not have those butterfly valves right ? i dont want the cyclone, but i like the jdm intake manifold better, i like how its laid out, not to mention that id have tos wap all the other stuff to the usdm manifold.
2. the a/c compressor, are the lines interchangable ? id just assume use the a/c compressor thats on the engine rather than taking it off and messing with all that bs.
3. does the " jdm " wiring harness plug right into the usdm ecu and still work properly ? because thatd be alot of sensor swapping if it dosnt, i belive thats it for the questions, help out if u know please, thank you
When I did mine, I used the following parts from my usdm engine.
CAS
Knock Sensor
02 Sensor
A/c compressor, I left on car and just bolted up to jdm engine when I dropped in the car.
Coil Pack and wires
Intake Mani and throttle body.
Coolant Housing
I think that is all that I left the same, but honestly there are tons of threads on this all over the net, look around a little on this site and another similiar site and you will find all the information you need to do this.
