Jdm/euro Taillight Wiring Issues
Jor-el
48
Mar 31, 2003
PK, New York
Hey have any of you guys wired up jdm/euro taillamps to function properly and had any issues with the fast signal? I followed that write up about how to make them light up as they would in europe or japan but when I put the directionals on the blink real fast I know what the problem is I just don't know if the resistor stated is the correct one or if the resistors I got are bad everything functions properly brake lights and hazards but the blinkers are too fast, just wanted to see if any one else had run into this problem while doing this mod and how they fixed it I'm not sure if I fried the resistors or not.:( going to get another set this afternoon. let me know thanks in advance.:thumb: :dsm:
Never mind; that tech article that was written on how to wire these lights to function like the Jdm/Euro lights was not 100% accurate maybe if I have time I will include the info that was left out, lights are funtioning properly now.
like to see someone figure out how to get a 2g talon to light up like a 2g eclipse.. I tried, but no luck, so just went with how the talon is wired up.
Thanks Rog, you know that I have been looking for them and trust me I would have gone with you but the money was right the time was right and I had to jump on them when I had the chance, and yes I will post pics they look awesome and the simple fact that they light up like yours do now Rog is the coolest part.
Project2g did you wire your lights up or did you just put them in?
guess I have to change my avatar now huh?
I pm'd Spidey and it turns out that he has the same problem I did with the fast blinkers, he never figured out how to wire them to flash at the normal rate. I told him how to wire them correctly and he is going to edit the tech guide and credit me with the added info so wait until he edits the guide and then wire them trust me I'll be same you some aggrivation. oh did your edm tails come with sockets on them? the ones in the corners are grey on the edm/jdm lights check to see if you have them because your going to need them. other than that they are awesome and when you get them to light up they way the should you are going to be happy. I know I need to get some picks up I'll try this week end.:thumb: :dsm:
