Auladan
- 304
- 2
- Jul 3, 2002
Shelton,
Washington
Okay... I hope I can word this coherently.
So! I own a 90 TSi AWD, and I melted the motor (timing). Now, I ordered a 1G JDM motor from, obviously, Japan. I have it bolted into the bay, and today I tackled the electrical.
And today I ran into some problems, as I figured I would. I had to take out the wiring harness from the JDM longblock in place of my old one, becuase it was cut. I got my old wiring harness situated just right, and started to fit everything together when I noticed several differences in the two wiring harnesses. The JDM one had a plug that mine didn't, and it plugged into this small box on the side of the throttle body. My old harness wouldn't fit where it was supposed to with that box in the way, so I was forced to swap Throttle bodies.
Out with the new, in with the old. So! Everything was peachy after that. I got some vacuum lines put into the Throttle body, and I did all of the injectors, then I notice another incompatibility. The spark plug coils on this JDM motor are located in a different, though admittedly better area. But, the electrical plug to them is different, and doesn't match with my old harness. The same plugs (the ones from both harnesses that do the same job) are different. The JDM one is more triangular, and only has three wires fed into it. On my harness, that same plug is more squarish, and has four wires fed in to it.
Now I'm stuck. I don't know what to do...
Then I find ANOTHER incompatibility. On the backside of the Intake Manifold is this small power fitting (for lack of a better word) where this rather large plug off the JDM harness fits in to. Well, the same plug on my old harness, that does the same job, is of a slightly different configuration, and won't fit. I can't find my old 'power fitting'.
Two problems I can't seem to fix. Ugh. Everything else matches up. Those are really the only incompatibilitie's that I could find.
So, after apologies for the long post and thanks for reading it, what do I do? Do I need to buy a 1G JDM wiring harness, or is the difference in harnessess only year-based? I don't know the year of the JDM motor.
Any help would be VERY MUCH appreciated. If needed, I can get pictures up soon.
Thanks again.
Thanks again.
.PM me if you are interested, later.
