dawgedeclipse
- 171
- 0
- Nov 14, 2002
I recently picked up my JDM six bolt. Now, i dont want this to turn into a why are you using the cyclone intake debate. Ive read enough of those. Im using it because I want to be different and my car is a daily driver.
Ok, i will be using the cyclone intake and as many of the parts that are on the car. The problem im running into is, are the harnesses set up the same. I do have the jdm ecu that was also pulled from the car so it matches with the engine. Is it pretty much plug and play? Or will I have to do some reworking on the wires for the coil pack and smaller power pack.
This is really my only conern. I do have the main harness down the the ecu that came with the motor but some parts have been cut and I dont feel like splicing that many wires.
