ISC Location
Prime85
83
Apr 13, 2009
Dania, Florida
Where is the ISC located on a 97 GST? i am having idle problems and i cleaned the TB i have a new IAC and a New TPS. the only thing i have left to try is the ISC but i cant find it.
Any help will be appreciated.
The ISC is located on the bottom left of the throttle body. Look down on the side where your battery is at the tb and it on the lower left.
No. look on the side where the throttle body elbow is andit is under the bottom left bolt holding the throttle body elbow on.
Different name same part. Take the battery out and look in there, there is an electrical connection that points right out at you, take it off as well as two screws and pull it out. Some people have luck with cleaning them but you can also test them to verify that it works.
