Isc Crazy
lou schmouder
271
Jun 17, 2008
dalton, Georgia
Can't get my isc to go lower then 50 . Won't idle below 1k and afr is 18/1???? Check sensor and showed good now what??
Even unplugged it no change
Make sure you have ZERO boost/vacuum leaks, especially around the intake manifold and fuel injector areas before trying to dial in your idle because it will not be right. If that is already done, check the ISC for proper resistance, replace if necessary and adjust the BISS.
This is what I did to get my ISC at around 30 according to link.
Boost test good all the way up to 43psi test isc reads right but think its just not function propary.
Remove the two bolts holding down the ISC and have someone turn the ignition on and off. It should click, whirl and extend in and out unless its seized up. There's a YouTube video showing a properly working ISC thanks to snowborder714.
[ame]http://m.youtube.com/watch?v=l7R3gf7SiAo[/ame]
It's moving very slow with no clicking Noise . Anyone know where to get a new one
I bought mine from DSMISC Automotive (New ISC Supplier) about a year back but it looks like their prices went up a bit but I may be wrong. You would have to shop around for the best deal and don't forget to buy a new O-ring too.
when i did that, mine didn't move at all? is there any way to check the wiring that clips to the isc?
Besides doing a visual check of the wires, I'd swap in a known good ISC from a buddies car for testing purposes.
