Is this exactly what i need?
Spaniel1287
195
Jan 30, 2005
Daven, Iowa
I am wanting to put a 14b on my 2g. If i got an L pipe to go with this kit. Is everything there that I need to install a 14b onto my 2g? And I mean everything? Thanks
I am assuming (and hoping) you were referring to a "J-pipe"..The pipe that goes from the turbo outlet on the compressor side to the LICP that attaches to the SMIC...To do the swap, you will need one of those, and most likely a new SS oil feed line to attach to the head and turbo...
Then, it would help to get some new bolts/washers and gaskets; at least a turbo-mani gasket (7cm if ported)
You could get a $150 install kit, or just make sure to get those important things and save like $30-50
Good luck
  • Wanted 6 bolt NT water pipe
    • chrisman287
