Is it possible to install overdrive on a gs?
You can get a taller EVO 5th gear installed. I had one put in my tranny from TRE. That will keep your rpms lower when in 5th gear.
I mainly did it because I have an Apexi N1 exhaust that was rather loud and droning when in 5th gear on the highway. My exhaust is now much quieter with the taller 5th gear. For slower driving in 5th gear around 50-60 mph, the rpms are between about 2k-2.5k. Although when going 80 mph, the rpms I believe are still over 3k and the exhaust is starting to get loud again.
Hope this helps.
Yes i think that is possible.But overdrives are usually close in rpm with the gear below it.Not much difference.The fifth gear you want will probably be smaller in diameter.Just dismantle your tranny,and search which 5th gear would work swell.
^^Said that the evo gear would be working right.So try to research that
goodluck
  • For sale Evo 8 steering wheel with dsm adapter welded on.
    Evo 8 wheel with welded adapter for dsm
    • 98TalonPandaTSI
