Forces32psi
- 103
- 2
- Apr 20, 2005
Belton,
Missouri
and if so how long will it last and what all could it be??? everything in motor is brand new except the head and lifters. head gasket, new springs, cams, pistons, rings, bearings etc. i started the motor let it run at 2500 rpm's for 10-15 minutes or until the motor got to 130 degrees an then shut it off, let it cool down, put anitfreeze in it and then restarted it, car has good oil presure, drove it around the block ran good. i wont be running it all weekend but as soon as i get home il be putting mobile 1 fully synthetic oil in it and changing the filter, it seemed to have a knockk around 2500-3000 rpms it hasnt run very long so im wondering if its just the lifters or something .. it doesnt really sound like a lifter "tick" though, pistons are coated w/ ceramic on top and teflon on the skirts.. any opinions or suggestion?? thanx steven
but only at 9psi max boost..
I havent monitored my knock sum yet because my Honda Civic Optima Yellowtop battery is crap right now
When I get a chance to monitor it, i'll post some more..
.. i should have known all of this before i put my motor together and checked mine.. i just didnt think i would have to. i dont know what size the ring gaps were filled to, il find out sat. im sure il be yanking the motor out sunday to go back to the guy that assembled it.. i think id rather just opt for a fresh block that isnt bored out yet and just use everything i allready have, if my pistons are still in good shape, i pulled the intake manifold off the other day, and #4 runner and port in the head had oil allover in it, but the car isnt smoking.. hmmm wonder which piston is slapping??? steven
