Is it necessary to get an alignment after a clutch install??
Any time a bolt or nut on a suspension is touched, the magic leaks out and has to be put back in on an alignment rack.
Of course, same applies to running over a Botts dot, so there you are.
Your tires and steering wheel will tell you if you needed an alignment. For after clutch work, "close enough" usually is.
On a 2G I got away with just undoing the upper bolt that holds the arm to the strut. That should be a minimal disruption to the alignment specs.
On my Talon I had to actually disconnect the spindle from the strut completly so my alignment is all over the place.
You tires will tell you if you need it or not.
Michael
:talon: :laser:
  • Wanted 6 bolt NT water pipe
    • chrisman287
