IPT Transmission
98TalonTSi
403
Aug 27, 2003
Readington, New Jersey
I had a trans meltdown the a week and a half ago, from a bad trans cooler.
I had a Translab shift kit and alto end clutch previously installed at 55,000 miles, after owning the car for about 6,000 miles.
The trans in that form lasted me through at least 25 drag passes, constant NJ traffic beating, and the regular open highway beating. It now has 70,000 miles. When we pulled the trans, it was "ok", but not great.
I went with an all-out trans, as IMHO, that is the only way to go if you're making some good power. I had a complete IPT race prepped trans, valvebody, and 4000 restalled converter. I also went with a 21,000 BTU trans cooler and a Phantom Grip LSD.
The car was night and day. The custom valvebody made the translab kit feel like slop. I was able to stall the car to 3800 without really pulling through the brakes, and I was at my max set psi of 18 in a few seconds. When I launched, I actually left to side by side burnouts next to each other...no more peg leg for me. Also, if I don't let off the gas a little bit after the initial launch, the car shifts into second sideways and just continues to spin...I think it's time for a dual stage boost control.
The customer service and support is top notch...in my opinion...THERE IS NO ALTERNATIVE. John, Brad, and Daron at IPT are the definitive answer for the AT DSM.
I'll post up some new times with and without slicks once I get to the track.
I will also keep everyone updated as to how everything is going.
IPT ALL THE WAY!!!!
Mike
Congrats dude. Sounds like you too like your trans......do you live locally to IPT or did you have your stuff shipped out to you?
I live locally and drove up there.
One more thing to add....
If anyone has an AT DSM and is just beginning to mod or is looking to further improve their car that is already modded, the Torque Converter is by far the biggest improvement and worthwhile mod I have done so far. Bigger than the head, cams, and all the other goodies I have done.
Mike
I dunno.......???
What mods do you have? Where is your peak torque beginning?
Mike
right itz all stock again
because it as recently stolen and replaced with stock items
Well, figure out your mods first, as far as what your goals are. If you mod your trans now, keeping in mind what those goals are, you'll be happier. Just think, the trans will be ready for the power, instead of having the problems most of us do, by beating the stock trans into submission from too much power, then having all sorts of problems.
Mike
