interior lights
o0-TaLoNbOy-00o
57
Oct 22, 2002
N-Dub,
my key ring light dosent light up so i took my ignition apart to see what is wrong with the key ring light and there was a bulb in there so i was guessing the bulb was burnt out. so i replaced it and still nothing!...im getting power in the wires but the bulb dosent light up!
anyone have any ideas?
check your door sensors, i know when my door open sensors went, my key ring didnt light up at all, even when i like jiggled them to get the interior lights to come on, it didnt. so i went to my local mitsu dealer payed like 5 bucks for a new pair and boom, works perfect now
so if you have your volt meter connected to the yellow/red wires and you open and close your door, you see between 11 and 12 volts for a few seconds then nothing? If you do, then there is a problem with the bulb or holder. If no voltage (keep in mind it will NOT be 13.8 or 13 volts but between 11-12) then you know it's an other problem.
