dsmBear
- 387
- 10
- Aug 27, 2012
Carmichael,
California
Hello. Yesterday I removed my intake manifold in order to install a new knock sensor. (Was runnining with out one) I reibstalled everything and used new gaskets on throttle boy and intake. Now a couole problems that are new (since the reinstall) on a warm start it raises idle 2-3k in nuetral for a while but when in gear drops normal.
The car will studded randomly, and abs and cel come on, then go off and car returns to normal.
And last but not least my big 16g was boosting fine and then I was driving and now I do no boost what so ever.
No spool or anything.
Also the oem temp gauge reads like the engines runnibg cold , above the first line. Any ideas? I'm so confused. I checked for missing lines and plugs but nothing
. was the egr gasket replaced? for 2g the egr had only2. one went to evap canister and other went to the egr solenoid.
