intake that will work with 2g maf and hx35?
I used one on mine with that same setup. It works.
The pipe fits with the 2g maf and you can order whatever size coupler you need to match your turbo inlet.
The maf to the fp intake pipe is a 4" coupler , then 4" coupler reduced to whatever from the fp intake to the turbo.
There are specific FP intakes made to work with the oval 2G MAS.
All HX35's have a 4" inlet, so you'd need only a 4" silicone coupler on that side.
I could've sworn the oval on the 2G MAS is 3-1/4" or 3-1/2", not 4".
From their site:
"The FP Cast aluminum intake pipe has an oval upper end that perfectly matches the shape of the factory 2G air flow meter. This shape coincedentally has a the same circumference as a 4" diameter tube, allowing standard aftermarket 4" cone filters to attach directly to the tube in applications where the 2G flow meter is not used"
  • Wanted 6 bolt NT water pipe
    • chrisman287
