intake pipe-->do i plumb vac lines
cbellsondsm
156
Jan 17, 2004
lake villa, Illinois
hey, i jsut got a hard intake pipe from a guy i work with and i was wondering if i have to plumb for the vac lines, i know i have to for the vented bov, but i blocked off the blow by line from the top of th valve cover but i have one left, is that the one everyone makes a catch can for or what can i do with it ?
no that goes to your charcol canister you can just aim it towards the ground, and why did you post this in the tuning section?
when getting an intake pipe, should u get it so there is that nipple on it for the vac line from the boost selonoid??? Cuz you can get the pipe with or without that...
it depends, if you are keeping the BCS then get one with a nipple, if you are getting a MBC at the same time the get one with out the nipple, what i would do is get the on with the nipple then if you do get a MBC then you can just cap off the nipple and if you ever decide to go back to stock you can still hook up the BCS
