intake and exhaust seals
IslanderTsi said:
What are you talking about. What intake and exhaust seal?
#6
VelocitàPaola
Car: 95 Eclipse N/T (w/turbo)
Dyno: TBAwhp/TBA lb-ft
Region: Southeast
Trader Rating: (2)
Reputation: Valve seals keep oil from entering the combustion chamber from the head - they don't seal the valves themselves. If air is escaping from anywhere in the head, chances are you need new valves altogether.
I guess the ones he is reffering to. Check out my other thread what are sign of bad piston rings
____________________________
-Paolo
no you should not have to remove the head from the car. It will involve a complete tear down though anyways so you might as well pull it and get it ported/polished new valves etc.
No problem. Just make sure you know what the problem really is before you start tearing thing apart though.
Good Luck
