Installing Wideband
Well I have my radio grounded to a black/yellow wire that is in that area. Does anyone know what this is, maybe it's not a ground. I think it's for the dimmer but what should it be connected to?
I did this yesterday in my car with the help of a friend. It took us 30 minutes top. Pulled the seat, had to cut the carpet a lil bit to have better access to the factory 02 sensor wire, unplugged it, went under the car and used a wrench to remove it from the catback. And then, i had my friend grind the hole (air tools) a lil for the wideband 02 sensor to slip through and tightened it. We ran the 2 wires (power and ground) put evrything back together and started the car. It's a plx m300. We used the cigar lighter wire for power and the chassis for ground.
That wire was the dimmer switch so it was causing all of my problems. The wire had nothing to do with the wiring of the gauge I just saw athat they were kinda touching and for some reason I connectd them. Now I don't have lights behind my cluster but thats my cluster. Do you guys no which relay is for the cluster and how much that runs?
I ended up figuring out that all my wiring was fine for the gauge it was that I had messed with the ground wire and connected it to the dimmer switch. This little mistake took me a while to diagnose becausse the whole time I thought I messed up something with the gauge wiring. It's really hard to fix a problem when where your looking there isn't one.
