Installing camshaft positioning sensor (distributor)
TT_NS
203
Dec 2, 2003
How do you tell which way to install the camshaft positioning sensor (distributor) into the cam (91 eagle talon TSI). i noticed a little dot on it but there is nothing on the cam to indicate which way it goes. i could end up 180 deg off. (I am using HKS cams and i still have the stock ones laying around)
Just so you know, a cam position sensor is not the same as a distributor, although a distributor is driven off the cam as well, they are not the same.
aight then where is the distributor on that engine then??? the distributor has the CAM in it
