Installing a shift kit and doing a tranny flush too
MitzMadness
130
Oct 3, 2004
Strongsville, Ohio
In about two weeks I'm gonna install my shift kit and do a tranny flush. I have an AWD and I'm wonder what do I fill the transfer case with and the rear differential, like any particular fluid or do I use the same as the tranny itself? Which specific Redline fluid should I use along with the lubegard?
Same question I asked about a month ago. I was told the transfer case and rear end took the same fluids as the 5 speed cars. Just go to Road Race or Slowboy and see what they recommend.
Manual Transmission Juice - BG 790, BG792 (Synthetic), or Royal Purple Synchromax
I'm sure i'm forgeting other companies that make it for the transmission i.e. Redline etc.
Transfer Case and Rear Diff - BG UltraGard 750, BG UltraGard 752 (Synthetic), Royal Purple Gear Lube, Redline Shock Proof Synthetic 80W. Or any gear lube really that has some high weight number to it, i.e. 75W, or 80W.
If this seems to hard to understand i apologize, call me and i'll explain better.
Cragger
For the trans I recommend Amsoil Universal Synthetic ATF and the bottle of black LubeGard.
For a full flush get about a case.
-John
