Injectors 2&3 not pulsing
chaggard27
191
Feb 8, 2009
Reno, Nevada
Ok I am completely stumped on this one. I have been troubleshooting sooo long I am doing it in my dreams. Here is the deal...I am working on a 99 gst auto that is not pulsing injectors 2 or 3 when running. While cranking engine the injectors pulse. Once the engine starts they stop and it runs on two cylinders. I have changed the ECU thinking that it could be an issue with leaking caps but no change. I have 12v to all connectors with key on. I changed the resistor pack, I ran a new wire from signal side of injector connector to respectable wire on ecu and nothing has fixed the issue. If I change the injector plugs the problem follows the plugs. I did a test by bridging inj 1 wire with inj 2 wire at ecu and same with 3 and 4 and the car then ran on all 4 with all the injectors pulsing. Problem solved right??? Not exactly how I want since this way it will use more gas since both injectors are pulsing on for each individual cylinder and I will run rich as far as smog. Also just to mention I have the nearly impossible to diagnose P0300 code. If I clear it then the car will start and pulse all 4 injectors right on startup and then it kills injectors 2&3. Any help will be GREATLY appreciated!
Just to clarify, your saying you've verified that that the ecu is or isn't pulsing 2 and 3 injectors?
Sent from my SCH-I500 using Tapatalk
When you say it follows the injector plugs what do you mean? Do you mean that when you change say injector 2 with 4 that injector 4 stops pulsing now?
Have you replaced the injectors? If you put injector 2 in injector 4's place and that injector still won't pulse I can only assume that that injector is bad.
It actually follows the connector. If I switch 2 with 1 then injector 1 doesnt pulse but 2 does. I know injectors are good because like I said they all pulse when cranking the engine. The ECU just stops sending a signal to 2 & 3 when it starts. I am thinking is is CAS or Cranks sensor....since they are a pair and usually when there are two pair cylinders misfiring it is a sensor. Just need a second opinion before having this guy buy random parts. Even though it wouldnt hurt to get new crank and cam sensors
Also if I bridge the injectors then the engine runs fine and all four cylinders fire and all 4 injectors pulse. Just will burn through gas that way and the tach does not show correct since the ecu only sees two cylinders firing...
Try the transistor and cas.
Are you talking about the power transistor? Because I get good spark so would that deal with the injectors as well?
So I decided to change out the crank position sensor and see if this solves the problem correctly or not. The CAS seems to be new so it should be ok. I may change it out with an extra I have to make sure and then I will let you guys know what I find out
I know this thread is old but did you find out what was causing that to happen? I'm having the same issue but with cylinders 3 &4.
