1G Injector Upgrade Question
a91eagletalon
Supporting Member
278
13
Aug 24, 2005
Norfolk, Nebraska
Few Questions
The car is making 537hp on a 6062 precision with one in tank 460 fuel pump
my goal is 650hp
I have now maxed out my PTE 1200cc Injectors and am ready to by new bigger ones
my question is I want bigger of course but I wont big enough for the future but I don't want to have bad idle problems with to big of injector because I will be daily driving this car every day.
I was planning on going to the FIC 1800cc Low Impedance Injector
Or maybe the FIC 2150cc High Z injectors but I am not real familiar with how these work compared to the low impudence injectors.
Not sure witch injector would daily better.
Thanks
MJP
High impedance is the way to go! All you need to do is delete the resistor pack. It's located behind the TB. You can get a PnP clip that plugs right in to bypass that resistor. Solder in the new pigtails, or get the PnP clips. I have FIC 2150cc's, have great idle quality with both pump and e85, and I make around 550 with 70% IDC on e85 @ 43psi base fuel pressure.
