injector question
i went out today and im makeing a solid 7 low, and 17 high.. so is my low setting too little and should a bump it up or is it ok where it is?
oldman said:
I don't know Steve, you and I have helped many people trouble shoot boost related issues where bypassing both mbc and bcs was a usually occurrence and none has ever report back running 6psi.
Perhaps the factory makes allowances for boost leaks :). Seriously, the test in the FSM has you check it at WOT in second gear at 2500rpm. It doesn't surprise me that have such a wide range to that test. They're only looking for wastegate operation, if it's lower than 6psi or greater than 10.4 psi they finger the WGA.
Anubis, why don't you set your low about the the stock setting is? Raise it up a bit.
Steve
actuly i think i might keep it where it is now unless it's going to damage something? my clutch is slipping now in second under 7 PSI if im not careful OMG
