luvmygst
- 814
- 16
- Oct 17, 2005
radford,
Virginia
Does anyone happen to know what chip actually drives the 4 injector drivers? I have a 1g computer that just keeps the injectors open all the time. I have checked all the actual transistors , emmiter resistors etc.. I just cant seem to trace where the driver signal comes from. I think the computer is trying to do the right thing because when I log the car(when you can get it to start) It give correct readings for the IDC and time in m/s for injector pulse, so the computer is trying I just cant find what is driving the transistors on to keep the injectors open.. Any ideas would be appreciated. Thanks
I have traced the drive back to one chip, that is fed off of the processor, I am going to repace it and see what happens. Like I said the logger says that the injectors were working fine. It gives me the IDC and pulse width, so I dont think its the procesor. I just replaced all of the emmiter resistors, as well as the resistor pack that is in the same area just in caseof heat damage. not to be a smart assI appreciate the effort to help but I have 2 degrees in electronics and know what the bce of a trans is. collector is tied to ground, the emmitter goes through 1 200j 1w resitor for each injector, then to the harness. Thanks for trying to help though if you have any other ides shoot em at me. Thanks
