PieEyedPiper
DSM Wiseman
- 5,580
- 65
- Nov 13, 2004
North Bay Area,
California
I just finsihed installing Illumina and Prokits on my car. So far so good, until I started to play with the adjustements. But I should give a little history on my car and it's situation. The car squeaks. Every time I shut the door or go over a bump the car will squeak. It does it also when I pushed down on either the front or rear end -this was PRE install.
I installed the shock and srpings and immediately set them to 4 in the front and 3 in the rear. I liked the ride it was comfortable yet stiff when I needed it to be.
The problem was noticed today when I set all shocks to 1. I was curious about the ride at those settings and I correctly set all 4 to the first position. As soon as I started to back out of my driveway I immediately noticed a hissing type sound whenver there was any suspension movement.
I got out of the car and pushed on the rear end and sure enough every little movement made a hiss. Upon returning the settings back to 4front and 3rear the hiss was gone and back was the squeak I had before the suspension job.
The squeak is odd because I excessively lubed up EVERYTHING I could get my hands on during the install, in an attempt to rid myself of any noises or squeaking with the new parts.
Summary:
For whatever reason the squeaking remains with the new install and when I set the shocks to 1 they hiss or almost whistle.
Also somehting to note on cause it might be the cause, is that I was shipped one of my rear shocks without the black rubber cap that protects the tops of the shock but al without the adjustment knob you put the screw driver into or the numbered gauged that fits on the top of the shock. I use parts form the other shocks (PITA!) to adjust that particular shock.
But what really tops it off is that I just noticed that the top of the rod sticking out of the shock the shape is squashed. The fronts are like this:
OO
But the rears are like this:
O0
It appears to be superficial damage from the factory or shipping but do you think it may be causing this noise?
Summary:
OO
O0
