Ignition key and hatch key the same?
mfilion
Mar 22, 2006
Fairport, New York
Tomorrow I'm getting keys made for the doors to my 91 by bringing in the lock cylinder to the hatch, but then I remembered that the ignition key to my 96 also opens the hatch. Are the locks on the doors and hatch of a 1g the same? thanks
I doubt it. Mine are the same. A key doesn't work in one try lubing it. I've had bad luck with a lot of cars having stuck hatch/trunk latches.
Could also be you've got what they call a Valet Key. Fortunately, I've got the Original ignition key and a Valet key for my car.
The Valet key operates the ignition and driver's side door, where the Original obviously operates everything on the car [hatch, glovebox, etc.].
I too have had to stick some PB blaster in the hole with the little red straw to lube up the cylinders...
After getting in on the passenger side for a few days it was a priority
