if u had a choice of 3' dowpipes which would u get.
Royalty
904
Apr 30, 2004
norfolk, Virginia
To clarify i'm not talking our dream down pipes
i'm talking about one of these.
MOST IMPORTANTLY I live in suckie VA where we have to have a cat to pass inspection. On that SS exhaust can i put a cat at the end of it? WHich one?
Apexi DSM Downpipe $204 from dsm parts
From their site:
A'PEX Front Pipes replace the factory down-pipe and catalytic converter and significantly improve exhaust flow. Stainless steel flex joints are used to dampen the cat-back exhaust system from engine vibrations. N-1 Front Pipes are manufactured using aluminized steel and treated with high-temperature titanium particle coating. A'PEX Front Pipes are for race use. These down-pipes will produce 10-25 HP Gain. Fits 90-94 Talon, Eclipse, Laser AWD Turbo.
or
Monza 3' Downpipe $210 from dsm parts
Fom their site
This Hi-Flow downpipe from Pace Setter features a 3 in. diameter, mandrel-bent, 16-gauge steel construction for maximum flow capacity and a T304 stainless steel flex joint for durability. It bolts to the bottom of the stock turbo housing and even retains the OEM oxygen sensor location.
or
DSMparts 3" SS Downpipe $209
From their site:
DSMparts Front Pipes replace the factory down-pipe and catalytic converter and significantly improve exhaust flow. Stainless steel flex joints are used to dampen the cat-back exhaust system from engine vibrations. DSMparts Front Pipes are manufactured using high polished stainless steel mandrel bent piping.
Ilike Apex personally. They have a nice turbo back N1 setup.
HyperGSX said:
$200 for an 02 eliminator downpipe? I believe RnR sells it for like $315 or something like that
Hell mine costed me $430 plus shipping. I paid extra for no cat and stainless though. Then I had to pay to get the o2 bung welded shut and a new one put on due to it being in the wrong spot. When I bolted it up I didnt realize that the o2 sensor poked a hole in the water pipe. Scratch one water pipe and o2 sensor.
I will also have to say pay a bit more and get a 3inch O2 elim. If you do it right once then you dont have to worry about it later. Let him know you need a cat and he will make it that way.
Michael
:talon: :laser:
so it looks like the apexi is the one for me. Will it bolt right up?
some one owes me $210 so i told him to get me a downpipe and call it a day
I'd go with the Apex'i just for the price and quality. But for a little more, RNR o2 elmin would be the ideal thing to get. RNR does great work.
no one has informed you that an apex'i N1 downpipe eliminates your cat... unless you want to remove the downpipe and reinstall the stock downpipe and cat before inspection time.
an RnR o2 eliminator downpipe will outflow ANY ported o2 housing. that said, if you want to make some big power, you'll want to upgrade your o2 housing, as that is a giant exhaust restriction. you can an RnR downpipe to retain the factory cat, and order 3" test pipe for when you're not at inspection. i don't know what RnR's turnaround times are now, but be prepared to wait if you order one from them.
here is RRE's info on Apex DPs
sharp change
short flex section
small inside flex
tab gonna break
bolt hole wrong
and finally.. installation of apex dp at RRE
So RnR is the best to order from, but how long is the wait? 2.5inch o2, 2.5" dp, 3" from hi-flow cat back? Pointless? Will a 3" turboback with 3" o2 be worthwile, affordable, and pass emmisions?
I am buying a RNR #" O2 Elim with no cat, and stainless, they seem to be the best out there, especially for the $. Just my $0.02
a 2.5" downpipe/3" cat-back combination is enough for 90% of DSMs on this site.
Agian, if you call Ryan and tell him you want a cat he will make it with that in mind. I would get the 3 inch O2 elim back. It will support anything you throw at it.
Micheal
:talon: :laser:
They (the guys at RNR) have been stockpiling most of their exhausts lately, so you shouldn't have to wait too long for it. Reminds me I need to contact Ryan...
sharp change
short flex section
small inside flex
tab gonna break
bolt hole wrong
Yeah, Apex are a buch of morons! :thumbdown Too bad I didn't have any of those problems putting my dp on. Those pics are nothing but a scam. Yeah, my ass Apex is garbage! :rolleyes:
I would have to say get the MEGAN racing 3' downpipe I have one for my Fast DSM and it works and builts up great to me APEXi N-1 exhaust with no problems at all, any ?'s just pm me :dsm:
