Ski Bum
- 231
- 3
- Nov 17, 2005
Citrus Heights,
California
I was hoping that some of you Mitsu gurus could help me diagnose an intermittent idling hiccup my GSX has. The hiccup is intermittently present at any rpm level while in neutral, I have not noticed any surging or power loss while driving.
First I suppose I should list what I have already replaced/fixed and we can go from there. My profile has my current mods as well.
- NGK BPR7ES, gapped to .028" (could they be too cold)
- New Accel 8mm wires
- Cleaned throttle body
- Vaccum/boost leak test (replaced gaskets, no longer leaks)
- Timing belt, balance belt and all drive belts
- Timing Belt Idler Pulley
- Timing Belt Tenshioner Pulley
- Timing Belt Hydraulic Tenshioner
- Balance Shaft Belt Tenshioner Pulley
- Water pump
- Oil change mobil one and factory filter (alot smaller than fram that was repalced?)
- new Oil cap
- New BISS screw and o ring
- new Thermostat (160*)
- new Radiator cap
- flushed coolant and replaced
- new fuel filter
- new o2 sensor
- refurbished ECU (motoguys garage from ebay)
Hopefully I didnt leave anything out. Along with that I have adjusted the base timing to 5 degrees advance and set the idle the best I could to 800rpms.
The car passed smog with flying colors and was actually very clean, below average in 2 of 3 categories, even here in California.
Possible problem areas:
- The car has a catylitic converter which could be clogged? Not sure about that, am planning on replacing with straight pipe.
- There is a slight exhaust leak between the turbo exhaust port flange and o2 housing flange.
- Upon inspection of the plugs there is carbon fouling on the lower half of the plug (on the threads, not the tip). Along with the carbon fouling on the plugs a black liquid sputters out of the exhaust tip. I dont have an AFR gauge but my hunch is that I'm running rich. Could the hiccup I'm hearing be the rich exhaust reigniting within the exhaust system?
Aside from that is there anything I have missed?
- Water pump
- new Oil cap
- new Radiator cap
- new fuel filter
- new o2 sensor
but if they can tell me exactly what is wrong and save me the trouble and time finding it on my own then I would feel its worth it. Hopefully I should get an answer by tomorrow.
He told me that if it was regular oil before then I could have actually hurt the engine by putting in synthetic at this point. I havent read anything to back this up but he said that all of the synthetic conditioners in mobil one (and other synthetics apparently) could have dissolved the "gunk" and "stuff" helping the rings seal the cylinders. He said that might explain why the compression went down so much in such a short time. Remembering back I performed the first compression test (154,154,152,154) before I changed the oil for the first time. A couple posts back are the newest results, depressing huh?
