ECMlink Idle & Small Cruise Logs - New Setup & New to DSMlink
First off, I see the tps on idle to be quite off, wideband is reading afr at under 8, huge maf compensation but no alternative maf listed in profile, injector compensation but no injectors listed in your profile, combined FT ranges between ~6% and ~9%, o2 takes 5 seconds to cycle and at least a minute and a half to start cycling?
That's all just from the idle log.
Need to revisit those ecmlink basic tuning videos and update your profile.
I updated my profile.
I will be adjusting the TPS and Idle Switch.
Injectors are FIC750, using a -39.8% global and a dead time of 315.
I have no idea why my MTX-L is reading 7.4 at all time. The gauge display does not. Using yellow wire for wideband signal.
I havent touched any MAF compensaiton stuff. Its a stock 2g MAF setup.
02 Cycling - Using the narrowband, brown wire, from the MTX-L to simulate narrowband signal. Obviously, takes a little for the sensor to heat up and read. Thus the delay.
New log.
Re-watched all the ECMLink videos and adjusted MAFComp.
Brought my AFRest way down to normal. CombinedFT is good. TPS is at 0%at idle.
