idle rev and 2nd gear popping out problems
roni-wan
155
May 4, 2006
merida, Central America
hello friends i have an eclipse gst 95 an i noticed that when i rev to 7k rpm with the 1st gear engaged and the clutch pedal full pressed tha car moves not much but it move like if your where letting off the clutch pedal without pressing the gas pedal i don´t think this could be normal
at idle when its on neautral if i push the clutch pedal and inmediately put the 1st it grids,
i have to wait after 2-3 seconds with the pedal pressed to not to happen
also while i am driving and make the change from 1st to 2nd gear if i dont pull hard the knob to second it pops out i mean it doesnt engage, if i pull it quite soft like the other gears the 2nd pops out so far all the gears when are fully engaged i have no problems
hope u can help me with some hints those problems really bother me really mad i am very corncerned about a tranny rebuild
sorry to say but i could be crankwalk. crankwalk will move the flywheel towards or away from the clutch and that could be your problem but i hope not!
Uh... the flywheel's bolted to the crank, and the clutch is bolted to the flywheel. They all walk together.
  • Wanted 6 bolt NT water pipe
    • chrisman287
