idle rate for an 1g turbo auto??
insaniti
72
Jun 12, 2004
Montoursville/Williamsprt, Pennsylvania
Im just wondering because I finally have my car running smoothly and steady. got a new ECM in, but it just seems that my car is idling a bit high. it drops to what I think would be normal once its put in gear, but still...
right now its idling at 1700 rpm, is the high? normal?
It should idle about 750-850 in drive. How I do it is pull the ebrake and put it into drive. Make sure no lights/fans/etc are running. If its within that range you are in spec.
Edit: Make sure the car if fully warmed up first.
Im good to go now, runnin steady at 1100 (the lowest I can get it, screw bottomed out), which is fine with me...
