IAC idea
turbo addict
482
Apr 17, 2005
Omaha, Nebraska
I had an idea for an external IAC housing. Why hasn't someone with cnc access made one of these to sell?? Someone could cnc a chunk of aluminum that a factory IAC will bolt into and have barb fittings so that all you woud have to do is run a vacuum line into the intercooler pipe on one side and on the other side run a barb fitting into the intake manifold and your done. All with the use of vacuum lines no cutting or anything! Instant factory IAC control on whatever aftermarket throttlebody you want!! Or if you have a block off plate for the factory TB to clean up the install, you could also run this and get rid of the bottom half of the factory TB that is in the way!!
What do you guys think????
Same concept but an external with barb fittings, that way you could run it on any throttle body: mustang, Q45, stock or what ever! and you could mount it anywhere with only the use of vacuum lines. And you don't have to have a special throttle body machined to fit it!!
