I think im finally dialed in
UNDR PSI
97
May 6, 2004
Plainfield, Illinois
16psi, 50 trim, 650cc, 100octane
Time RPM Timing 02
0.20- 1560.0- 19.0- 0.92
0.50- 1636.0- 19.0- 0.92
0.80- 1708.0- 19.0- 0.92
1.10- 1776.0- 20.0- 0.94
1.40- 1860.0- 21.0- 0.94
1.70- 1920.0- 21.0- 0.94
2.00- 2004.0- 21.0- 0.94
2.30- 2080.0- 22.0- 0.96
2.60- 2160.0- 22.0- 0.96
2.80- 2240.0- 22.0- 0.96
3.10- 2308.0- 22.0- 0.96
3.40- 2392.0- 23.0- 0.96
4.00- 2548.0- 24.0- 0.96
4.30- 2636.0- 26.0- 0.96
4.60- 2708.0- 26.0- 0.96
4.90- 2808.0- 26.0- 0.96
5.10- 2916.0- 26.0- 0.96
5.40- 3004.0- 26.0- 0.94
5.70- 3092.0- 24.0- 0.96
6.00- 3224.0- 24.0- 0.96
6.40- 3296.0- 23.0- 0.96
6.60- 3420.0- 22.0- 0.96
6.90- 3552.0- 22.0- 0.96
7.20- 3640.0- 21.0- 0.96
7.50- 3796.0- 19.0- 0.98
7.70- 3884.0- 16.0- 0.98
8.00- 4028.0- 14.0- 0.98
8.30- 4224.0- 13.0- 0.98
8.60- 4348.0- 13.0- 0.98
8.90- 4464.0- 13.0- 0.98
9.50- 4816.0- 13.0- 0.96
9.80- 4960.0- 14.0- 0.96
10.1- 5144.0- 14.0- 0.96
10.3- 5308.0- 14.0- 0.98
10.6- 5368.0- 15.0- 0.98
11.2- 5580.0- 16.0- 0.98
11.6- 5688.0- 16.0- 0.98
11.8- 5824.0- 17.0- 0.98
11.9- 5952.0- 17.0- 0.98
12.3- 6212.0- 19.0- 0.98
12.5- 6376.0- 19.0- 0.96
12.7- 6440.0- 19.0- 0.96
13.1- 6564.0- 20.0- 0.96
13.4- 6760.0- 21.0- 0.96
13.8- 6968.0- 21.0- 0.96
Thats what I wanna know. You could get away with more boost than that on PUMP.
im running 100 right now because next thursday, it is getting dyno tuned for 28psi, on 100 octane. The shop that is doing it, told me to run 100 octane for a few weeks before the tuning. Ive just been playing around with the tuning the past few days for the hell of it. Timing looks good though???
Mike
What are you "what???"ing? Tuning for knock?
When I said, "What does the butt dyno say you make for horsepower?" I was asking how it feels? Are you satisfied with your 50 trim?
~Mark
thats why i said what...the knock thing. I have to go off timing. It pulls hard, even for only the 16psi im pushing now. I love the 50 trim....and to think its not even effecient until 18+psi. As it is now i walk all over z28's and hang with c5 corvetts. Im getting it tuned for 28psi thursday and i cant wait to see the HP on the dyno with that, let alone the"butt horsepower" :) Im sure i will be much more inpressed with what i feel vs. what i see. Thanks for the replies.
-Mike
mavisky said:
yes, but that's still not the same thing exactly.
You're right, however, the onset of knock is present by the slope of the timing curve. So in essence, he *could* tune for knock :thumb:
Whatever, he'll get on the dyno and tune it with a WB. Problem solved, done deal.
~Mark
I am quite capable of seeing knock in degrees of timing pulled and in raw counts. Yeah, it's a 2g...
The log looks ok but you'll probably love it more at 28psi.
-T
yea in essence, you can tune for knock if u think of it that way. Because anytime your pulling timing a decent amount there is knock. Were all right.
Good Luck with the dyno ... why again did he want you to run 100 octane a whole week in advance again? Aside from making sure that you were completely empty of regular gas. How are your EGT's? That should give you a good indication without a wideband of how lean you are.
I think 28 psi is probably on the high side, why did you pick that number?
I think 25 psi sounds a lot more reasonable.
Well the shop told me it would be a good idea to run it for a bit before hand. My EGT's are good, around 1500 at top of 3rd and hold steady. I get the car back today, cant wait to see what she can do. And i picked 28psi, because that turbo can handle that all day long. Plus with all the time and money i spent over the winter building this car, 25psi just wasnt high enough. The car is built to handle 600whp, and the turbo is capable of 28+psi......so i figure i got it at hand, why not use it.
