I Need Help Asap!!
sholace29
46
Mar 21, 2005
Montpelier, Idaho
Ok I just got me a 98 Eclipse GS-T, and put a rebuilt engine in it from my 96 eclipse that I wrecked. I got everything hooked up and wired up, and when I went to start it, all it does is sit there and crank. What could be wrong? I do not have the original key, and I have not programed my code into my stereo yet, because I didn't find the code until my 3 try were up. What else could be wrong?
check your basics
fuel
spark
fuel - can you hear your fuel pump priming? do you have pressure at the test port? is your injectors clogged?
spark - check the resistance in the wires, check the plugs, are you in the right firing order? check the coil
also check your fuses make sure nothing is popped. then go from there
would your wrecked eclipse start when it was wrecked? before you took the motor out to put in the 98?
we didnt want to try and start it after the wreck becuase it took out my radiator, and turbo. So did they ever make a chip for the key?
