I Need Gaskets!!!
cbellsondsm
156
Jan 17, 2004
lake villa, Illinois
im rebuilding my engine and need all gaskets associated withe rebuild, lover and upper engine, my question is where should i get them, i dont want to go to satan becasue a few bucks for a gasket here and there all ads up ive checked out the toplines here http://www.slowboyracing.com/more.php?id=1126& but ive heard theyre total crap, what should i do, also how are the cometic head gaskets? ive heard theyre comparable to hks but is that true thanks
chris
I went with a full Topline kit for my engine rebuild including pistons and my motor is good. At 10 lbs of boost, it's pulling like a champ and no problems with anything from Topline yet.
i used a topline kit in my rebuild. but i used a eagle/ross combo too. you can i beleive just buy the gaskets if you plan on useing other pistions and rods. anyhow 21psi with 700 miles on the engine w/ my 50 trim and its going strong
I used the topline kit, but I also bought an OEM intake manifold gasket and OEM throttle body gaskets because I didn't trust the ones that came with the topline kit. I also didn't use the topline headgasket and the topline kit doesn't come with a turbo to O2 housing gasket so I had to also buy that seperate. Other than that no problems with topline and no leaks.
  • Wanted 6 bolt NT water pipe
    • chrisman287
