what gaskets do i need for my 14b install
ohio98eclipse
365
Aug 4, 2003
anyhow i havent gotten around to installin this damn thing because of crap weather anyhow i keep lookin at all the faqs i can and they all say different crap about the gaskets...was wonderin which ones i will need and i dont mind buying new ones. im also porting the turbo and all that fun stuff so what gaskets will i need to make sure i dont go to big and than my gasket dont fit no more.
if your running low on funds like i always am just reuse your old gaskets and put RTV gasket sealer on the Oil return line gaskets otherwise they will leak. If you want to buy new ones the gaskets you will need will be the exhaust manifold gasket(felpro makes a good one), Turbo 6cm or 7cm gasket(slowboy racing has them the cheapest ive seen), 2 Oil return line gaskets, and 02 housing gasket(its metal and reuseable), and last but not least the 02 housing to downpipe gasket. Ive changed from a 14b to a 16g and reused the same ones over and over as they were still in good shape. The only ones i replaced were the 2 Oil return ones becuase they only cost me $1.35 each from mitsubishi.
