I have searched and want to verify, timing issues....
Eclipse45150
103
Oct 1, 2004
Milford, Ohio
I was wondering I saw the vfaw, the page in the service manual, and various other places about how the timing marks look to line up for tdc. Upon searching I have founs that the are suppose to be 6 o clock on the intake and 12 on the exhaust, is this correct? My issue s that when set across from each other my car wont start, I have just got done rebuilding my motor and double checked everything after it wouldnt start so the only thing I can see is that the timing is suppose to be set to 6 and 12, please let me know so I can redo timing tomorrow if I need to.
Oh, and also should the dowel be right behind the timing mark or the cam gears or is it off from it? I ask because I dont have a yolk to hold the cam gear to take the bolt out.
you do not time the engine by the dowel.
With the VC off the motor, rotate the cams. you can see a hole in a rough area of the cam between cyl 1 and 2.
Rotate the crank to TDC cyl 1 which is the mark on the crank. Now rotate the cams so the holes are pointing straight perpendicular to the VC gasket surface. The MArks on the cam gears should be facing each other like the diagram in the book shows.
Terry
Can a mod please move this to the appropriate section?
  • For sale Mishimoto Intercooler
    Universal Mishimoto Intercooler $100.00 Brand new
    • jmt2028
  • For sale 2g Mahle Power Pak Pistons
    2g Mahle Power Pak Pistons, factory bore $350.00 Brand new with wrist pins and extra set of...
    • jmt2028
  • For sale 2g Water Neck/Thermostat Housing
    2g OEM waterneck and thermostat housing $60.00 In good condition, came off 1995 Eagle Talon Tsi
    • jmt2028
  • For sale EVO 9 Blow Off Valve
    EVO 9 blow off valve $60.00 In good condition, came off 1995 Eagle Talon Tsi. Comes with factory...
    • jmt2028
  • For sale 2g OEM Camshaft Gears
    2g OEM Camshaft Gears $80.00 In good condition, came off 1995 Eagle Talon Tsi Comes with OEM...
    • jmt2028
