I dont know what I SHOULD do here (fresh head reuild)
95weclipse
307
3
Jun 26, 2009
LaSalle, Illinois
Alright so I rebuilt my motor over the winter, did all the work my self except the machining part, I put new valves in the head because I got a good deal on a set of SS valves, bronze valve guides, and 3g lifters, well I didn't have the head surfaced like I should have ( I didn't have a job at the time but now I do). I did put in new stem seals. All I did was lap the new valves in and didn't have the guides put in. My car started smoking the other day:ohdamn:, so I decided to investigate and what I did was pull my manifold to check the seals and yup they are leaking:banghead: so now that I got a job I am thinking about pulling the head, having it surfaced, 3 angle valve job, and have to guides put in, only problem with me not having it surfaced and guides done and pulling the head is, I dont have another car, so what should I do here I have to get to work I cant keep using my moms crappy explorer its a gas pig. I know you can pull the springs and seals with the head on the car should I just buy the tool and do it in the car and wait or what. Any suggestions will help out
In short, doing it right once costs less in the long run if your worried about money. Sure it may seem like it costs a little bit more but look now - your having to tear it completely back apart, who knows what may break from now until then, you'll need a new headgasket etc. Hopefully those loose valve guides didn't beat up your new valves :(
