Humming noise
Viper588
131
Oct 4, 2006
manalapan, New Jersey
hey my 95 gs has started to get a humming noise that gets louder the faster i go,it seems to be coming from the front of the car and when i turn to the right at all the noise goes away...from the searching iv done its seems to be the bearings but didnt know whether there was a way to check for sure and whether to change one or both? thanx
Classic symptoms of a wheel bearing starting to fail. To check which one it is, jack up the corner of the car, enough to get your hands on the top and bottom of the tire. Try to wiggle the tire, up and down, in and out, side to side, as if you're trying to wiggle the wheel off. If it wiggles back at you, the bearing is failing. If it's tight, move to the next wheel.
