For Sale Huge list of new 1g/2g parts
Talontsi79
58
22
Apr 18, 2016
Guthrie, Oklahoma
Prices do not include shipping or PayPal fees. MAKE AN OFFER!!
-New in box VIS Invader 1g Carbon Fiber Hood. Pickup only. $500 PENDING
-1g AWD fuel pump sending unit. $45 PENDING
-Brand new in box ETS 1g street Front mount intercooler. $275
-1g ETS J-pipe powder coated wrinkle black. Perfect for 14b/16g/20g $SOLD
-New STM timing belt tool kit. $SOLD
-New Street Ray's 4g63 valve spring tool $50
-NEW 4g63 crank tool $20
-New ARP 4g63 head stud kit pn#207-4201 $75
-New ARP 4g63 main stud kit pn#207-5401 $55 PENDING
-New ARP 4g63 6 bolt rod bolt kit pn#107-6001 $30
-New 6 bolt ACL oil pump pn#OPMB1096 $SOLD
-New 4g63 Gates timing belt kit pn#TCK167 $55
-New 6 bolt 4g63 timing belt tensioner
Pn#T43215 $50
-New 6 bolt thermostat housing $15
- New 4g63 crank pulley $20
-New OEM rear main seal plate, gasket and Fel-Pro seal $45 MD040330/MD183243
-New Gates 6 bolt water pump pn#42163 $SOLD
-New 1g 85mm pistons, rings, wrist pins, King standard main and rod bearings. $80
-New 1g 6 bolt full engine gasket kit $SOLD
-Extreme PSI Aluminium spark plug cover $40
-New Extreme PSI 4" aluminum intake w/ new K&N filter $SOLD
-New 1g motor mounts. Drivers side, front and rear mounts. $SOLD
-New Innovative Water temp/ Volt gauge. PN#3853 $100
-2g Dejon Tool intake with K&N filter, 2g ma $SOLD
-6 bolt flywheel resurfaced ready to go. $80
-New Forge atmosphere dump polished BOV kit. $SOLD
-New OEM 1g BOV w/ oem gasket MD160689 $100
-New OEM 2G BOV dump tube $SOLD
-New 1g knock sensor $40 PENDING
-New 1990 1g 90amp alternator w/ new plug $100
-New KYB AGX 1g awd rear adjustable shock $SOLD
-New 1990 coil pack $80
-New 91+ 6 bolt coil pack $80
-1990 coil pack w/ JMF sheetmetal intake mounting plate $50
-New 6an pushkov black braided fuel line kit 16ft, 4 straight, 2 90°, 2 45°, 2 180° fittings. $40 PENDING
-New 6 bolt oil pan $50
-New 4g63 valve seal tool. $20
-New oil pressure gauge relocation kit $25
-FIC 650cc high-z fuel injectors w/ delete plug and adaptor plugs. This make install simple. Used about 500miles. $SOLD
-Precision 680cc low z injectors. Used for dyno run and changed out $100
-New 1g ARP stainless exhaust manifold stud, nuts, washer kit. $SOLD
-New ARP stainless exhaust manifold to turbo bolt kit for Forced Performance manifold $25
-New Gamble Garage 1g Power steering Resivor. $50
-New in box weapon R universal coolant overflow bottle. $40
-New 1g/2g brass shifter bushing kit $SOLD
-New ARP cam tower bolt kit pn#107-1003 $60
-New ARP cam gear bolts pn#107-1002 $15
-New STM polished 2g cam sensor housing cover $SOLD
-New DNJ 4g63 freeze plug kit $10
-New Glow Shift 30lb boost gauge $30 PENDING
-New MicroGuard 2g stock Air Filter $10
-New 2g Glow Shifttriple a pillar gauge pod $20
-New 2g 85mm Nippon pistons, rings, split thrust bearing, King STD main and rod bearings. $80
- New Yonaka 1g aluminum radiator w/ aluminum shroud and slim fans. $190
-New in box 2g oil pump w/ gasket $40
-New 4g63 Accel yellow plug wire set $20 PENDING
-New NGK 4g63 blue plug wire set $SOLD
-Good used Walbro 255 fuel pump $30
-New VooDoo manual boost controller $10
-New black halman style boost controller $10
-New 6an silver bulkhead fuel fitting $5
-New blue Aluminium oil filler cap $10
-New 10an aluminum oil drain fittings with gasket and bolts for 14b/16g/ 20g TD05 style turbos. 4 available $10ea
-New 10an black push lock oil drain fittings 1 45° and 1 straight $10
-New Marshall fluid filled fuel pressure gauge for adjustable fuel pressure regulator $15
-Brand new OEM drivers side 1g power side mirror $50
-New Coils (4) with plugs for Coil on plug setup. $40
-New super tech intake and exhaust valve seals 4g63 motors $20
-1g gauge cluster with 0 miles on it. $100
-New MAC electric boost controller solenoid for use with DSM Link. Includes mounting plate and screws. $30 PENDING
-Brand new 1g MAF Translator w/ new 3" GM mas, silicone couplers, t bolt clamps and 1g throttle body to side mount intercooler pipe. Flared for the GM mas. This is literally a complete kit. $200
-4g63 turbo long block w/ engine stand. Pulled from a running parts car I had. Car had 102k when pulled. $550
Theres a ton more stuff I haven't listed so if theres something pictured that I haven't priced shoot me an offer. Feel free to text me 405-446-7162. Thanks
  • Wanted 4G63 Wanted
    Looking for a kiggly HLA
    • steelcurtaindsm
  • For sale 2g 1998 Eclipse GST Rust Free
    Rust free, not perfect, prob needs motor soon. 125 compression all 4
    • Zanaqqq
  • For sale 1g Int door plastics MB517837 and MB517834
    • ist dwa
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted FIC Easytune
    Looking for a FIC Easytune box.
    • Stapl3
