HUBStands discount
snowborder714
Moderator
16,188
465
Oct 15, 2006
Mechanicsburg, Pennsylvania
I'm guessing no one will be interested in this, but I'll put it out there anyway.
$50 off a set of HUBStands using the attached PDF file! These things are amazing for doing corner balancing and alignments since you don't have to keep removing the wheel or jacking the car up/down. You can see them in use in my blog entry.
http://www.dsmtuners.com/forums/blo...-new-suspension-corner-balance-alignment.html
Let me know if you have any questions on them!
You have some cool shit there, Brah!
That I do. Expensive, for sure. But cool.
It needs more than fifty off for me to get. Not in my budget. Thanks for posting.
No problem. I figured it's only a part a limited number of people can use, and even less can afford. Honestly I debated on picking these up really hard and for a long time. I at first couldn't stomach the idea of dropping $1k on a part that just holds the car up. But once you've got it up and you don't have to jack it up, remove wheel, make adjustment, reverse process, it almost immediately pays for itself.
It took me 10-15 minutes tops to corner balance my car. If I wouldn't have had these, that time would probably be 2-3x more.
