How to remove T25?
Kyogie12
306
Feb 14, 2010
Boulder, Colorado
So i searched around for a bit and couldn't find anything on it...
I want a link/video or what have you on how to remove the T25 from the Engine, i wanna know how complicated it is for me to install my own 16g, or if i should take it to a shop to do it. So far i've done all the work on my DSM myself because that's what DSMs are for!
Thanks
ok well for removing, first i take the intake off, next i remove the 4 exhaust manifold bolts, then i remove the 2 bolts for the oil return line(10mm), then i remove all the coolant and oil lines that go to the turbo..!!! its alot easier to remove the turbo with the radiator fans off...!! last but not least i remove the 2 (17mm) nuts that go from the turbo to the downpipe... hope it helps and if you have any questions.. keep us posted
