2G How to read error code?
aahsan
May 5, 2004
Ypsilanti, Michigan
Hey Guys,
New to the forum, I have a 95 GS-T, I havve the CEL lit how do i check the error code?
Do i need to buy a reader to get data from the OBD? Or will the CEL light blink the code?
Thanks,
Aqil
Oh BTW!
I think I have the famous " Hot start problem ", any easy fix for this?
Thanks
Solution
The easiest way is to go over to autozone, they will scan the code for free. Then tell us the code(s) and i'll look it up for you. Maybe the hotstart problem is related to a code you are getting. Good luck!
Solution
  • Wanted 6 bolt NT water pipe
    • chrisman287
