How to measure unsprung weight
bigfoot
389
Aug 30, 2002
Tell me if this works and add suggestions please.
With car on jack stands, pull tire, dissconnect tie rod and remove shock, replace tire and put a scale under it.
Add half of shock/spring weight or not? If I unbolt everything, half of axle?
This is for a GVR4.
Approx. 2G AWD unsprungs: front = 65# + 40% of shock & spring + 100% of wheel & tire; rear = 40# + 45% of shock & spring + 100% of wheel & tire. No idea about other DSMs.
I used the "remove the shocks and springs, loosen all articulation points, and then stick a bathroom scale under the rotor" method to get these values. Correction welcome.
- Jtoby
c5chris, Was that the correct link? According to that I don't need to count control arms, shocks or axles. Strange.
