How to get car started after sitting 2 weeks in garage being repaired
Matrixhunter
205
3
Sep 17, 2005
Toronto,
Hey guys just finished installed new tranny car doesnt seem to want to start i put some gas in same almost starts. Any ideas what the correct way of priming or starting a car that has been sitting for a while? thanks.
check and make sure its getting fuel, and spark.
Fuel: turn it over a few times pull spark plugs out smell for gas
spark, pull spark plug wire off, put the electrode thats inside the wire against a metal surface, have someone else turn the motor over watch to see if it arc's.
also, since you mentioned you installed a new trans, you may have had to unplug the signal wire from your MAS (airbox area) check and make sure it is plugged in.
