2G How to check timing
Reliable GSX
5
Feb 22, 2017
Tampa, Florida
Hey guys, so I recently ran into some issues with my AEM v1 ECU, but fixed it with some friends of mine. I was told by one of them to make sure the timing is fine, since we were messing with the tune on the ECU a little. I've been looking, and can't find much help on how to check the timing on my car. I have a 1998 Eclipse GSX. I was told I just need a timing gun and some free time, but again, I can't find much help on how to actually do it. Has anyone checked/adjusted their timing on their 2g and can point me in the right direction?
I am familiar with the EMS. You setup your timing in 2 steps. This is also assuming that you can start your car & it will run good enough "as a starting point" to tune.
STEP ONE
A) Connect up your timing light.
B) Connect your lap top to the ems & start your car. Goto > Configure > ECU Setup > Set ignition...
C) You should get this window
. It's worded kind of hookie but your timing light needs to match the display as close as possible (in this case 10.07*).
STEP TWO -You need set Pickup Delay Comp.
This is an option you will find under "full list".
This value is an offset between when the ECU receives the input signal and processes it. Every sensor has an inherent delay from the time an event actually
happens and the time that it signals the event electrically. This delay is very short but at elevated RPMs, it can account for timing errors of over 5 degrees. The way this is setup is to check the ignition timing at idle and then at an elevated RPM. If at idle the timing is correct (agrees with the computer screen) and when at elevated RPM the timing reads higher on the screen than the timing light indicates then the Pickup Delay Comp has to be raised until the timing agrees with the screen.
Lastly, this will not change anything in your timing table. This will ensure that the values that show in your table are actual what is displayed. In a nut shell this syncs the mechanical to the electrical.
Awesome, thank you all for the help! Turns out I had to use the timing light on the crank pulley, along with slightly adjusting in thru the AEM software. Was quite a pain to mess around with, but all is well now. Thanks again!
