how similar is the Big T-28 compared to the Big 16 G ?
please do some research before asking. and of course someone correct me if i'm wrong, i'm doing this on the top of my head
bt28killer ~550cfm
e316g ~ 565 cfm
t28 is direct bolton to a 2g, 16g is direct bolton to a 1g; and no, the installation isn't that much harder.
t28 spools faster, 16g has more topend
thanks for the info i did do some research but no one seems to know if the intake wheels are the same or not or if the exhaust wheels are the same. it seems to me to be some secret turbo. i just wonder if the wheels are the same.
thanks for the replies. :thumb:
the t28 killer has a BIG 16g compressor wheel and the turbine side has to do with top end. The evo, big16g and t28 are similar...BUT the 16gs will pull harder at mid to high rpms have better top end, and put down more hp. The big t28 will work a bit better on the drag and autocrosse cause of VERY quick spool and awd means mean launches, and quick boost when exiting the apex. But when it really comes down to is that a t28 killer and big 16g will behave ALMOST identical, so really all you have to look for is one that flows 550 or more cfms and go with the cheaper of the two :thumb:
Andrew
